I’m a total newbie here so please be gentle ;->
I have a dcc deck that came with a Technics stereo system I bought a couple of decades ago that I have never used. My recollection is that it worked fine for a bit then started acting up on dcc tapes. It plays analog tapes fine but the dcc output is kind of regularly intermittent every second or so. I have only tried it with pre-recorded tapes and it happens with all of them. The meters show the drop outs even though they are very short. Occasionally it will play a few minutes before acting up. I haven’t tried recording anything to see what it does.
I have the service manual and I’m not completely unfamiliar with electronics but the thing is really surplus to requirements so I don’t want to spend lots of time and money on it just to junk it. If anyone has some possible easy fix suggestions or troubleshooting procedures I’d love to hear 'em - clean the heads? aztec(?) angle?
In any event it’s going up on eBay but I don’t hold out much hope for a sale being all the way down under in New Zealand.
Thanks for your help and kudos to you folks keeping old tech alive!
Jac,
Thanks for your responses. I’ve been away and very busy so haven’t had this small problem much on my mind.
I did have another brief look at it yesterday and here is what’s happening:
Analog tape - seems to play a music fine on both A and B sides with no real noticeable wow and flutter but the output is very low and there is a constant hiss. Both sides are the same.
DCC tape - side A plays at reasonable volume but has intermittent drop-outs about once a second but the drop-outs are not regular in time. Side B doesn’t play at all.
I did clean the head with alcohol and a cotton bud and the DCC playback on side A got better but only briefly.
Thanks drdcc, you’re likely right, I was just hoping there might be a simpler fix. Oh well, I’ll put it up on eBay and if no takers it will get sent to the electronics recyclers.
Not after you harvested the still good parts and send it over to the dcc museum… these heads become very scarce, and if yours is still good, Ralph can use that someday to help another enthousiast!
So if it is not too much to ask… dismantle it and send it to dcc museum…
