Problem with Philips DCC600
Hello.
I bought a defect DCC600. Seller told me “tray will not open” I replaced the belt and that problem was solved.
But the recorder did not play. Turned out the gear was broken. I replaced the gear and the recorder did play, rewind and forward.
But no sound. Then I saw that one of the cables from the head to the circuit board was loose. :frowning: Is this repairable?
Cable is loose on the head side.
Hello.
Finally got the dcc600 repaired.
Used the head and R/W board from a donor (DCC380 with broken gear and display not
working) to fix the DCC600.
