Is there a solution for the noise my Philips DCC 951 is making when playing a cassette? It’s peeping short when I turn it on, and something when playing a cassette too. Not constantly. I hope you’ve got enough information. I like to hear from you. Kind regards Kris
Hi and Welcome.
If the sound comes when playing a tape, it is the felt pad inside the tape, also called the slip stick effect.
Felt pads can easily be replaced.
It happens when there is no tape inside, at the point that I turn it on, it’s peeps for a bit and then stops. Also when playing the tape but that’s not the case I guess because it happens when there is no tape inside.
I understand that, but the question is when you play a analog tape, if the playing speed is to slow possibly? Use a cassette with audio material you know well to test.
