Philips DCC 600 no title display
To add to my DCC 730, that doesn’t record, I’ve just bought a DCC 600. This one records & plays but has a couple of problems.
When I first insert a DCC cassette, it says reading, sometimes it searches for the first track & then as I press play, the title of the track appears for a split second. Then it just shows track title for the rest of the time I’m playing the cassette.
When I press the title key, it displays album name & artist but no detail about tracks or song title.
In time mode, it only shows counter but not the title time.
In record, the time shows & appears to separate tracks but nothing is shown on playback.
The quality of sound is good on DCCs & it plays analog tapes very well.
I’ve cleaned the heads, using the recommended IPA & brushing gently with a cotton bud, from bottom to top but it made no difference.
It doesn’t always auto reverse straight away at the end of the side on DCC either. In service mode, the heads all show zeros.
Wondered if it was anything simple to fix (unlikely, I know).
Thanks, Rob.
Sounds like a problem with the encoding of the data on the (prerecorded) cassette. There’s nothing you can do about that.
Reminder: self-recorded titles from the 730 cannot be read by the 600.
Hi Jac,
Thanks for your reply. I have 3 pre recorded tapes & the fault is there on all of them. The recorded tapes I bought weren’t recorded on my 730, as that doesn’t record, as from my previous topic. I bought them recorded but I’m not sure which model they’d been recorded on. The DCC600 does record on them but my other (730) appears to record but has no effect on the recording already on the tape.
Best regards, Rob
Ps neither home recoded nor pre recorded show the number of tracks or time in playback, when text is selected.
Hello,
Sometimes I have the same problem with my… very used analogue second hand at least… DCC300.
When purchased this equipment it was blocking cassettes and it was a signal of several bad usage. After repair the opening frame arm inside, starts playing all kind of cassettes without problems of sound.
Related the original PreRecorded cassettes, sometimes it gives and sometimes don’t give any name, but plays correctly … and track name is the most usually when info is missing.
I suspect of degradation of head or his azimute with tape… but… when I start the cassette from the very begin side A all the info appears… or… I turn Off and On and starts with all info.
Also helps clean the head.
I keep this equipment, and I have several 3rd generation models, because it’s the only one that never make any drop-outs on sounds on my recorded cassettes!
Best
Jorge
