Hello, I have a Philips DCC 600, which worked perfectly. One day he stopped. When you press play, it stops in a second, do not go forward, do not go back. I thought it would be the gear, it would be broken, it was indeed broken. I changed it, when testing its operation it keeps doing the same thing to me, I press play, and it stops. The drag tape, I touch it with my finger and it looks light. Could you tell me what could happen to him? Thank you
Hi and Welcome,
Is the new gear ok? No broken parts/teeth? Did you get the gear from the dcc museum?
It could also be the pinch rollers.
The equipment was ok, I bought it second hand, internally I don’t see any loose parts, and I don’t see any broken teeth. I have replaced the broken gear, and I have replaced the pressure rollers. The gear engages the teeth perfectly to the wheel. I haven’t changed the drive belt, because when I bought the parts, it was out of stock at the DCC Museum
When I insert the tape, it wants to start and stops, tries to start on the other side and stops. It did the same thing, when it stopped working, by putting on a tape.
Before it stopped working, it seemed like it sounded like cicadas. ever sounded that way. I don’t know if they would be from the dcc tape.
Could it be that the motor is broken, the one with the gear?
It could as the gear you received was tested here in a player.
The belt should not be causing this issue either and the pinch rollers are new.
One thing you could try is a drop of oil under the new gear (contact bottom of the player and bottom of the bigger gear) and then first wind a tape completely Forward and Backward 2 times and try and press play again.
Hello
i’m new to the forum, i have the same problem, i’m going crazy i don’t understand what it can be
in addition to play, it also gives the same problem with fast forwarding and rewinding. it starts for a second and then stops.
I put on new gear, new belt, new lubrication, removed the old grease and put new,
someone has found a solution?
thanks
Gabriele
Maybe the motor sensors. There are threads about that problem in the forum.
thanks!
I think it is not repairable ..
I have two identical models, in the first the head cam does not even move, the one that makes it approach and turn for side b, if I mount the mechanism of the other the defect is identical so there is something on the motherboard the solenoid that operates does not move, I checked there is no voltage to the solenoid.
in the other recorder I have the defect that pressing play after a second stops, so also for fast forward and backward.
with the other mechanism I have the same defect .. so there is something on the motherboard of the second player
I have never had so much bad luck as with these two damned players
from two I can’t get one to work
of discussions on engine sensors I have not found much
you could point them to me before throwing it awaya threads on motor sensors I have not found much
could you point them to me before throwing everything away?
any suggestions are appreciated
A thousand thanks
Gabriele
