I have reccapped this deck, but someone misaligned the Aztech heads screw.
I ask if is possible to re-adjust the Aztech adjustment. On the SM i don’t find this adjustment.
Is possible to re-adjust?
If Someone did break the Seal of the azimuth adjustments, it is best lt go into the Service mode, choose all errors and adjust, side a and b until there are no Errors. You can use a pre-recorded tape for this,
Thanks, i have it.
But i make a rough adjustment with this.
I have find hidden on my compact cassette a Scotch 3M dcc tape.
I have played this and aligned roughly the azimuth…
and sound perfectly both sides
Sadly after one playback, the felt pad detach from the cassette :-/
But i’m really happy it’s play with very zero error rate.
