Great catch. In order to keep it working ,you must replace the capacitors asap to not risk damaging your DCC900. It is best to not use it before you either replace the capacitors or check if they have been replaced. If you do not see any leakage… it does not mean anything unfortunately.
Great that it is also 240V, so you do not need to worry about replacing the transformer, like we discussed.
