Our data only shows 146mA to 180mA.
Since the voltage across the jumpers is then calculated between 1.285V (146mA) to 1.7V (180mA), it is safe to assume that your voltage should indeed be around 1.1V.
The IREC moves between 22Ohm and 57Ohm on that data. on R167.
Can you share what replacement adj resistor you bought to replace and where?
