So I’ve had this DCC900 since 1998. I bought it as clearance for $25 (!) and a Philips employee gave me 3 tapes when they found them at a warehouse. Way back in 2000 that DCC player was working flawlessly. Nowadays, not so much.
I found it in my attic the other day after watching a video about R/W board. So I plugged it in and was greeted with some recordings I had made 25 years ago. It played ok. But i only played for a few seconds to confirm it was working.
So i took it apart and indeed, two caps were starting to leak. I replaced all electrolytics. I used mostly ceramic caps for the job (since I have a lot of SMD parts), but for the 63uF ones I replaced them with 100uF, and the 2.2uF NP too.
After putting everything back, it did play. It plays analog just fine, and it was playing DCC for a while. So I tried recording. Using an optical cable from my PC I recorded at 48KHz, hit rewind, play, it worked. woo.
so i tried recording a little more. and that’s when everything started failing. After those few recordings it no longer plays. But I’m not sure if it’s something else. I don’t know if it’s the pinch rollers, the felt pad, or an electrical problem. I tried service mode and in All errors mode i just see random garbage in a known recorded part of the tape. This is after trying to clean the pad which, i think, just made it worse since the pad is a little “deformed” now (i assume it’s not making proper contact against the head).
When playing, though, it does detect the parts that are recorded at 44k as 44k, and the B-side of the tape, which i recorded at 48k, is detected as 48k. It also (sometimes) stops at the markers. It even detects marker number.
Should I stop what I’m doing now and somehow try to find a “known good” tape? The other two tapes I have are somewhere in the house, lost to time, sealed in their original package. I haven’t seen them in years.
I think it may not be related to the recapping. It COULD be a broken flex cable but I don’t think so. I don’t remember sticking anything magnetic near the head.
Anything else I can try before trying to buy a new DCC tape?
