DCC600 not playing
Can anyone help please. After replaceing belts on my philips DCC600 and repairing power supply switch , when i put tape in and press play the mech engages capstans spin then it stops and wont play , ff or rw.
What am i missing please. It was working years ago when last used.
Both capstans spin freely.
Mech engages.
Head moves to tape but cant see and tape movment.
Cheers
Paul.
You’ll have to take a closer look to see if the capstans and pinch rollers are turning.
It’s also possible that you broke the infamous 2g gear; it was originally made of soft plastic and it goes brittle and breaks. The DCC Museum has replacements at Gear set 2nd Generation « DCC Museum
Thanks for that i will take alook at pinch rollers and gear.
I know capstans are running as ive seen them spinning.
Cheers for that.
Paul
After dismantaling deck i found the gear drive with teeth missing. So will be ordering replacement shortly as well as new rollers, might as well while decks in bits.
Many thanks for the help.
Paul.
Found the problem. New parts now orded from DCC MUSEUM.
Cheers guys.
Great pictures of the problem. Unfortunately all the 2nd gen suffer from this.
The new gear will solve the problem.
