Philips DCC 600. After replaceing both belts, pinch rollers and the dreaded 2nd gen gear my unit still wont work.
It knows there is a tape in digital or analoge but will not stay in ffw or rrw or play. Head engages then shuts off.
Ffw or rrw moves tape as long as you keep pressing the buttons.
Am i missing something or am i slogging a dead horse.
I followed all dr. Dcc videos now im stuck.
There might be a mechanical failure. Was it having the same issue before replacing the parts?
We have had this problem when the mechanism is not put back together correctly sometimes.
When you put the the two parts of the mechanism together (the parts with the gear/pinch rollers) and the sliding part, sometimes the side sensors get affected. Either brake, or loose. Double check.
Well managed to get it to ffw and rrw ok but still wont play, just shuts off. I couldnt try it before because gear was broken thats why i orded new one from yourselfs.
Had mech in my hand to see whats moving or not and all motors are running ( captans ) new gear moves into place and runs.
Im guessing sensor ( tape end one ) so it thinks tape has ended because when play is pressed and it shuts off it changes direction and tries that way.
Mech apart again. Hahaha
Tried everything all looks fine.
Fast forward and rewind ok now but still wont play.
If i use a DCC tape it sqeals before stopping.
Anologue plays for 2 sec then stops , switches sides does same then stops.
Behond me.
All wires and switches preasents , motors running, engage smooth. Lost now.
I have a sensor fault on supply reel, if i apply preasure to the board the playing will play without issues.
As for the squeak with Dcc taps i watched your youtube video and yes felt pad was dirty in the tape.
Playback sound awsom, just goto fix contact problem and machine is fixed.
My 2nd generation DCC600 player is exhibiting the same symptoms as those described in this post.
After replacing the fragile gear and the drawer and capstan belts, I’m still having a problem with my player. It exhibits the same symptom (playback starts and stops https://youtu.be/Ab9d22_ujng).
Paul, could you share a photo or tell me where the sensor on the feed reel that was faulty is located?
Could you help me find the source of the problem?
Regards
Pierre
There are two sensors, one for each reel, once i correctly positioned mine it worked so i managed to secure it and now it hasn’t failed once.
Just remember your may not be same so bare that in mind and your could still have a broken sensor LED or dirty sensor wheel plate that is attached to each supply and take up wheel.
I don’t know how to attache pictures but if you click on my profile picture you will see both reels on the deck, just bellow them is a creamy color circuit board this is where the sensor is attached to and also this is what i had to secure on mine to get it working.
