Hi. I have a DCC 951 which has a channel imbalance when playing analogue tape. Fine for digital. Are any if the surface mount capacitors in the analogue audio chain ?
Also how does the replay head work? Could there be a head issue ie it will play and record digital but not analogue?
Thanks for this. Are the r/w board caps in the audio signal line ie does the audio signal pass through them or are they control caps or something else?
Could the issue be on the main board?
If the head is reading the digital signal ok does that mean the head us fine or is the tape head split into different parts ie one part for analogue and the other for digital?
P.s. Looking at the r/w circuit diagram it is suggesting the analogue signal is read by a separate ‘coil’ and that the signal does run through at least two 10uf caps. No 2827 and 2826
