Dcc-91 playback issue
does anyone know how to fix this problem?
I put in a tape. Press play, it plays 1sec switches sides plays 1sec and stops.
When I open the tray the tape has a small loop of aproximately 1cm sticking out.
It played fine a couple of tapes, but since it was a thrift store find who knows how lang it has been sitting without playing or maintenance.
It needs a new gear. The idler gear on 2nd generation decks like yours was made of soft plastic and due to age, they all go hard and brittle, and then they break. And then the deck doesn’t drive the reels anymore so when you hit Play, the capstan pulls the tape out and it spills into the recorder which thinks it’s reached the end of the tape because there’s no signal from the tachometers.
Replacing the gear is not difficult but you’d have to get one first. I think the museum is out of stock at this time, unfortunately.
The gear you need is available on some Chinese webshops. They call it “gear for DCC900”. But it is for a DCC recorder 2nd generation.
Thank you! Maybe ill fix it. Maybe i sell it cheap for a hobbyist.
Changing the gear is easy? I saw the museum YouTube video on it, seems quite difficult to me. :joy:
if its this one, looks to be in stock?
That is the one and it is in stock.
I read on the Dcc site shipment is from Friesland, since i live there(Friesland) is pick up possible? Maybe get some tips for repair
It is best to order from the store as this is for patreons only.
