I have a couple of issues with my DCC 900. These may be unrelated.
- Analogue playback only on right channel. Left completely mute, VU meter does not move. This problem was there already when I bought this used couple months back.
- Left channel almost mute. If I turn balance on amp to left and increase volume enough, I can hear the music silently. Digital output gives both channels at equal levels, and VU meter shows both channels working.
- Occasional dropouts on digital playback. First it was really bad, but after playing for a while, dropouts became less frequent.
- Unable to play side B. On both analogue and digital playback, side B stops after second or two. This is likely a mechanical issue caused by me, but I was unable to figure out what I messed up when I opened it up and took a look at the belt, as I thought that issue #3 may be caused by loose belt.
Any advice would be appreciated
