Hello all, I have a strange issue with my DCC170. After buying it in the 90’s I stored it and try using it again. The belt was gone and needed to be replaced. Thanks to the instruction video I was able to do it. The switch part is the hardest because you can’t see it clearly.
After finishing it was time to test the player. It starts, plays DCC tapes and recognizes analog tape or digital. Unfortunately no audio on the digital or analoge tape. It forward and Reverse are ok. Tape keeps “playing”.
What could be the cause? Thank you for your reply in advance.
If all the cables are connected correctly after the restore, it usually is either the head or pinch rollers.
In this case it might be the head or a problem on the main audio board, as you have no audio when even playing analog cassette.
