Last week I replaced the belt and the SMD capacitors of a DCC 134 I bought. The player will go fast forward and rewind but it will not play. There is no clicking sound of the solanoid.
If I swap the main print from another 134, it works ok so it must be in the main circuit board.
Does this sound familiar to anyone?
Thanks.
Kind regards, Erik
Not really. Did it work before you replace the capacitors? Remove the smd caps again and check if there are side A-B connections on that board that might be broken.
Hi Ralf,
Thanks. I’ll have a look.
Erik
Issue is solved now. It was a solder joint on connector JU02. Its working again ![]()
