Hi!
I have bought a used DCC 134 not working. I changed the belt (compared to the 170 you don´t have to desolder the pins from the motor and the switches). But the DCC playback is not working. Analog playback is ok but a lot of wow and flutter. If you press “play” you see the tracktime and the absolute time but no sound.
I checked the service menu and found that the heads show FFFFFFFF. Regarding the AUX-data i get between 1 and 3.
I havn´t changed the smd caps because they look good.
Does anyone have a idea? I don´t think that the head is the problem as analog is playing well.
Thank you
Stefan
